Very Few Features on Vision Assistant
Updated Dec 30, 2025
  • Vision Assistant
After upgrading NI Vision to a newer version, I see a very limited number of features on NI Vision Assistant. For instance there is only Edge Detection under the Machine Vision category.
It’s likely that you selected an FPGA target from the startup menu. Try opening the LabVIEW application to explore additional features. If the issue persists, please contact NI Support.
