Simulate a SwitchBlock Device in NI MAX
Updated May 5, 2025
  • PXI Carrier Module for SwitchBlock
  • Matrix Module for SwitchBlock
  • NI-SWITCH
I need to simulate a SwitchBlock Device in NI MAX and I can not find my device in the list of simulated devices available.
You will need to have NI MAX  installed on your system as well as NI-SWITCH in order to complete any of the steps.
1- Open NI MAX
2- Right-click in Devices and Interfaces and select Create New
3- Select Simulated NI-DAQmx Device or Modular Instrument and click in Finish
4- Search the PXI-2800 and click in Ok
5- Now in the list, you will see your simulated PXI SwitchBlock device, select that device
6- Select Insert or Remove Simulated Cards within the NI SwitchBlock
7- Select the model of your card in your preferred slot and click in Ok
Once you created your device and configured the slots, you will see something like this:
Next Steps
Now you can create your code in LabVIEW using NI-SWITCH with your simulated device. Here you can check how to begin using NI-SWITCH in LabVIEW.
