Archived:NI Data Dashboard Support for Sound and Dialog Box
Updated May 14, 2025
  • Data Dashboard for LabVIEW
  • iOS
  • Android
  • Is it possible to include sound and custom pop-up dialog messages in the Data dashboard?
  • Does NI Data Dashboard support sound and dialog box?
Note: NI is no longer updating Data Dashboard and the Data Dashboard download is no longer available on the App Store nor Google Play. Consider using WebVIs for your LabVIEW-based web application needs.
Data Dashboard for LabVIEW is a mobile application that enables the creation of custom user interfaces that can monitor and control LabVIEW applications remotely.
NI Data Dashboard does not support sound and dialog box. You can only use it to connect to the values of network published shared variables and/or web services using buttons, text input and display, charts, gauges, and LEDs.
