This issue is a known bug with the FlexNET software used in our licensing technologies. Please see Additional Information section for more insight.
While we are collaborating with the component vendor to fix the issue, currently there is no fix to the issue. To avoid the issue, use one of the workarounds mentioned below. For all workarounds new license files are needed, please contact NI Support for more information.
- Using a backup-server that will bounce-in while the first server is not reachable because of the issue
- In order to implement this an appropriate IT structure is necessary.
- This workaround will not prevent the issue from appearing, but provide a backup system for ensuring that all clients can continue working.
- Using several servers by splitting the license file for reducing the number of clients per server
- This would prevent the issue from appearing as it is depending on a critical number of clients set-up and connected.
- All clients can be divided into organizational groups at different locations which makes it easier to distribute them to the different servers.
- A well-considered distribution strategy can offer further advantages such as an existing free space in time where maintenance work can be carried out on the servers.
- On each server it should be checked regularly if the critical number of clients has been exceeded. If this is the case a new server must come into place.
- Handling new permission requests through a new server while freezing the configuration of the old server
- The issue only appears on a server if there are permission changes to be applied. If the configuration of a server is not changed anymore the issue won't appear.
- This workaround can also be used for having a smooth transition to the second workaround. The effort for setting up new servers is minimized.
- Make sure that the automatic permission handling is deactivated on the current server (see Additional Information)
- Any new user or computer should be directed to use the new server.
- New license files for all servers are needed.
