Calling MATLAB® Scripts on NI Real-Time Targets
Updated Nov 24, 2022
  • CompactRIO Controller
  • LabVIEW MathScript Module
Can I run a MATLAB® Script (.m file) on NI Real-Time targets, such as a CompactRIO?
You can use the MathScript Node of the LabVIEW MathScript Module to run the instructions contained in your .m file on an NI Real-Time target.
Refer to Using MathScript Node in LabVIEW for information on how to use the MathScript Node.
There are certain MathScript functions that are not supported on Real-Time targets, you can find additional details in: Support for MathScript Functions in Real-Time Applications.
Depending on the functions, data types, and syntax used, LabVIEW might execute code at run time that can cause increased jitter and unbounded execution times in a real-time application. When determinism in an application is important refer to the Guidelines for Using LabVIEW MathScript in Real-Time Applications (MathScript RT Module).
