When I attempt to run a Self-Test on my NI-XNET device in NI Measurement & Automation Explorer (NI MAX), the Self-Test fails even though the device appears in NI MAX.
I receive the following error:
The self test failed.
NI-XNET (Hex 0xBFF63005) Board self test failed(code 5). Solution: Try reinstalling the driver or switching the slot(s) of the board(s). If the error persists, contact National Instruments.
