Wrong Signal Level When Using Source Opcode With Digital Pattern Instrument
Updated Sep 11, 2020
  • PXI Digital Pattern Instrument
  • NI-Digital Pattern Driver
In NI Digital Pattern Editor, I use Source opcode in my pattern to output predetermined frames to communicate with another device. I noticed that at high frequency, there are level errors in the generated bits.
Why does the Digital Pattern card transmit wrong bits?
When you use the source opcodes, you must add a delay of 3 µs between the source start opcode and other source opcode.
The delay is required otherwise you can get errors in the transmission.
If you want to learn more about using the source opcodes in NI Digital Pattern Editor, please follow that link: Digital Source and Capture Opcodes
