The steps to determine if the Host Memory Buffer is available can be found in the ‘
Configuring the Host Memory Buffer ’ topic of
NI CompactRIO Device Driver Help. These steps can be performed even without the actual Single-Board device using the simulated version inside the project. To accomplish this, create a blank project, right-click Project>>New>>Add Targets and Devices>>New Target or Device>>Real-Time Single-Board RIO. After adding the device in the project, follow the steps as explained in the previously mentioned ‘
Configuring the Host Memory Buffer ’ topic.
