USRP 2974 Single-Device Streaming Example Compile Failed
Updated Sep 11, 2020
  • USRP-2974
  • LabVIEW Communications System Design Software
I have already install LabVIEW Communications and able to detect my USRP 2974, when I try to run USRP-2974 Single-Device Streaming shipping example the compilation failed stated the error below :
Make sure that you have already install a compatible LabVIEW Communications Real-Time on your USRP 2974. For example, if you are using LabVIEW Communications version 3.1 on your host PC please make sure that your USRP 2974 have installed LabVIEW Communications Real-Time 3.1 .
  1. You can download the LabVIEW Communications Real-Time Target Image
  2. Find Installing LabVIEW Communications Real-Time Image sub topic in this link to install the image into your USRP 2974
LabVIEW Communications 5.0 cannot be use with USRP 2974 because LabVIEW Communications Real-Time Target Image only support up to version 4.0
