Error -2147467261 When Querying SQL Database
Updated Sep 9, 2020
  • LabVIEW Desktop Execution Trace Toolkit
Other
SQL
When I try to select data from SQL Database using LabVIEW I get the following error in LabVIEW Desktop Execution Trace Toolkit:
Error -2147467261 (LabVIEW:  (Hex 0x80004003) Invalid pointer.
NI System Configuration: A required pointer parameter was NULL.
This error appears when 1 or more columns in the SQL dataset contain NULL values. To avoid this error, the NULL values should either be removed from the dataset or replaced with default values when selecting them in value, such as below for numeric values:
SELECT ISNULL(myColumn, 0 ) as myColumn FROM myTable
