Error -307702 When Deploying VeriStand System Definition to Real-Time Target
Updated Aug 28, 2026
  • VeriStand
  • Simulink
I am deploying a system definition file to my real-time target from VeriStand; the system definition includes a simulation model I'm deploying to my target. When I deploy, I get the following error:
Error -307702 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: The size of the imported model data in the system definition file conflicts with the size in the specified model file. This error can occur if the model file contains a different number of inports, outports, signals, or parameters than when it was imported. This error also can occur if two or more models contain a global parameter with the same name but different dimensions.
What are some steps I can take to solve this error?
As the above error message notes, this error is typically caused by either a mismatch between a model's data and specified data of that model in VeriStand, an issue with global parameters for your project's models having the same name but different dimensions, or the use of non-Unicode characters (such as Chinese characters) in model or parameter definitions. Below are some steps that can be tried for these scenarios.
  • For issues with model data size mismatch:
    1. To ensure that your models are referencing their DLLs correctly, remove the models present in your project, save your project, and re-import the models into your project. Ensure that when you re-import the models, you are specifying to import the models with parameters as shown below.
  1. If the issue persists after re-importing your models, you should check to ensure that your Vector Port Specification is correct for your imported parameters. This setting controls whether or not inport/outport vectors are imported as a collection of scalar channels or a single vector channel. Scalar channels are easier to connect to other parts of your system but could result in data mismatches if you try to map a port broken into scalar channels to a model expecting a vector channel - the appropriate implementation will depend on your project. Vector Port Specification is another setting in the "Add Simulation Model" dialog box.
  1. If your issue persists, you could run the System Definition vs Model File Compare Tool, an open-source tool developed to compare System Definition and Model File parameters to determine mismatches. Correcting issues revealed by the tool should resolve errors dealing with model size mismatches.
  • For issues with global parameters:
    1. If you don't need your global parameters to apply to all of your project's models, the easiest way to resolve dimensional conflicts with your global parameters is to change the scoping for your global parameters from target-scoped to model-scoped. Model-scoped parameters will apply changes to only the parameter in the model that owns it, as opposed to all models that use this parameter. The process to update the scope of parameters in a model can be found in the VeriStand manual under Scoping Global Parameters - before changing your parameter scope, be sure to determine what the scope of your parameters is.
    2. If you need your parameters to be target-scoped, you must reload your System Explorer window and verify the dimensions of parameters loaded in multiple models. This information can be found on the Model Parameter Configuration Page, which can be reached by opening the System Explorer window and selecting one of the parameters for a model. Ensure that the dimensions of parameters used by multiple models match, and match what you're expecting the parameters' dimensions to be.
  • For issues related to non-Unicode characters:
Ensure that model names, parameter names, and related definitions do not contain non-Unicode characters (such as Chinese characters). The presence of such characters can lead to unexpected errors or incompatibilities in VeriStand. Replace any non-Unicode characters with standard ASCII/Unicode-compatible characters and reload the project to verify whether the issue is resolved.
  • For issues related to renamed model files (DLL/SO):
VeriStand stores a reference to the model binary file (such as a DLL on Windows or an SO file on Linux RT) when the model is imported into the project. If the DLL or SO file is renamed after the model has been generated, or if the file name is changed before importing without updating all related model references, VeriStand may be unable to correctly associate the model definition with the corresponding binary. This can result in model loading failures, parameter mismatches, or data size mismatch errors.
To resolve this issue:
  1. Verify that the DLL or SO file name matches the name expected by the imported model.
  2. If the model binary has been renamed, restore the original file name or regenerate/rebuild the model using the desired name.
  3. Remove the model from the VeriStand project.
  4. Save the project and reopen it if necessary.
  5. Re-import the model using the correct DLL or SO file and ensure all model files are located in their expected directories.
    After re-importing the model, deploy the project again and verify whether the error has been resolved.
    The deployment error can be caused by VeriStand IO blocks. As a workaround, you can mark the signals as Test Points before deployment.
    It seems the parameters work fine as long as there are no VeriStand IO blocks present. Making the signal a Test Point prevents it from being optimized away or combined during code generation, ensuring the variable remains distinct and traceable on the hardware.
    If none of the above steps resolve the issue and you are importing a model from a third-party source/external developer, ensure the model is properly configured before importing it into VeriStand.
    Make sure to update your software to the newest version and check if it's compatible with the toolkits or drivers you are using with VeriStand.
