When creating an Acceleration Task you need to know the specifications of your sensor such as
Sensitivity and
Iex Value.
When using custom scales the
Sensitivity and the
Custom Scale, both, are applied.
Take into account that the
Sensitivity is not a scale is just a conversion factor.
You can input the
Sensitivity factor in a
Custom Scale as the
Slope, however, take into account that for this to be accurate the
Sensitivity should be 1 V/g or 1000mV/g if not the
Sensitivity factor and the
Custom Scale will be applied affecting the output of your signal.
If you would the idea of a
Custom Scale is to input the
Sensitivity factor as
Slope, we recommend you to not use Custom Scales as this will be redundant.
