I'm currently using the PXI-4070 and I want to create some custom cables for it.
I checked on the
front cable specifications for the PXI-4070 and I can see that it uses banana plugs and a 9 pin mini circular DIN connector.
However, there is no information on the size and type of the connectors.
What are the appropriate specifications for the connectors if I want to create my custom cables?
