Compiler Error Dynamic IUse Node Has No Reference VI to Call in TestStand
Updated Nov 3, 2020
  • TestStand
I'm using NI TestStand to call a LabVIEW code module and I get a Compiler Error Dynamic IUse Node Has No Reference VI to Call. What should I do to fix this error?
The error generally means that the VI being called in TestStand was not compiled correctly. To fix this error try to:
