Missing NI-DAQ Support After Upgrading to NI-DAQmx
Updated Sep 10, 2020
I upgraded from NI-DAQ to NI-DAQmx and my LabWindows/CVI project says I'm missing support for some NI-DAQ functions. Why is that?
NI-DAQmx does not use the same functions as NI-DAQ. You must either:
  • Edit your LabWindows/CVI project to used the NI-DAQmx functions instead
  • Revert back to NI-DAQ and continue using those functions
