The error -1074118553 occurs because the Double Data Rate mode (DDR) and the Extended Data mode can't be used simultaneously. This happens because the data width for DDR is fixed at 2 bytes, while the Extended Data mode requires a 4 byte data width to operate.
The Extended Data mode can only be used when Single Data Rate mode (SDR) is configured, since SDR can be set at both 2 or 4 byte data width. For more information about data rate modes, please visit
this website.
