The article walks through how to make a measurement from bridge-based load cells, a step-by-step instructions for wiring and configuring your NI data acquisition device for strain gauge measurements. The principle also applies for bridge-based pressure and bridge-based torque sensors. The steps will be using an NI CompactDAQ system with an NI 9237 four-channel simultaneous bridge module and walk through setting up a Global Virtual Bridge Channel in NI Measurement and Automation Explorer (MAX) and testing the signal measurement and then where to find a LabVIEW example to start you application.
This article assumed basic knowledge of load cells, pressure, and torque transducer operating principles. Please review
Measuring Load and Torque with Bridge-Based Sensors, to understand fundamentals of load and torque measurements and how different sensor specifications impact load cell or torque sensor performance in your application, and
Pressure Measurement Overview, to understand basic pressure concepts and how different pressure sensors work.
