When connecting more than two relays (Independent Topology) using the NI-SWITCH Soft Front Panel I get the following error:
Error -1074118621 occurred at niSwitch Connect Channels (single)
Possible reason(s):
The number of relays attempted to be driven on this device has exceeded the relay drive limit for this device.
This error is shown in the following dialog box:
