Archived:Install NI LabVIEW Student Edition Using Windows Installer
Updated May 28, 2024
  • LabVIEW Student Software Suite
  • LabVIEW Student
The following document explains how to install LabVIEW Student Edition using the traditional Windows installer. This will likely be installation media that is in DVD format or received from an Academic site administrator and does not require the use of NI Package Manager.
This experience is tailored for this installer suite, but a similar experience exists for other software installations
Note: The last available version of LabVIEW Student Edition was released in Spring 2020. For alternatives to the LabVIEW Student Edition, consider using LabVIEW Community Edition, which is free for non-commercial use.
Considerations
Installation Order
Before you begin the installation process, it is important to review the installation order of NI software. Following the correct installation order is important as modules, toolkits, and drivers require the initial layer of the development system to be installed first; if this installation order is not followed correctly, the LabVIEW Development System will not be able to access the functions available in those modules, toolkits, and drivers.
Because the Student Edition and Student Edition Software Suite are in fact suites, they bundle together several installers and install the software in the proper order automatically. If however, you were installing these products individually, or later decide to install other software, you would need to note the installation order.
Downloading LabVIEW Student Using NIPM
If you have downloaded a newer version of LabVIEW Student Edition, you may be prompted to use NI Package Manager to complete the installation. Follow the prompts in NI Package Manager to complete installation and skip the Install Software section below; then, if applicable, continue to the Install Hardware Drivers (optional) section. Principles of installation order, selecting software to be installed, and next steps provided in this document are still applicable even if using NI Package Manager, although the exact steps and images presented below will not align perfectly.
Install Software
  1. Download  the version and bitness of software you need from LabVIEW Student Edition Suite or obtain the physical media from your site administrator.
    • If you have downloaded the software from an offline installer or from a network location, locate the installation files and double-click setup.exe.
    • If you have a physical DVD, insert the LabVIEW Student Edition or Student Edition Software Suite DVD into the DVD drive of your PC. If Auto-Play is enabled, the installer should automatically open and begin to initialize. If not, locate the DVD and right-click and select Explore. Double-click on Setup.exe.
  2. Allow the installer to initialize and then select Next.
  1. Select I only want to evaluate products. Select Next.
    • Note: You can activate the software with your serial number after completing the installation as discussed in the subsequent tutorial: Activating NI Software Products
  1. Select the products that you would like to install. To add a product, left-click and select Install. To remove a product, left-click and select Do not install. Select Next after selecting all desired software.
  1. [Optional] Check for Updates for your software before installing.
    • Depending on when you install your software, it is possible that there have been updates released for your products. At this point, you can choose to contact NI to see if any updates exist by selecting the checkbox that says "Search for important messages and updates ...".  This is not required, and can also be done using the NI Update Service after installation. To proceed without doing this, deselect the checkbox. Select Next.
  1. You can modify the installation path, but it is not recommended. Select Next to proceed without changing the default path.
  1. You must read and agree to the License Agreements—two windows contain license agreements. For each window, select I accept and then select Next to proceed.
  1. Before you proceed, ensure that all desired products to be installed are listed accordingly. Select Next to proceed.
  1. The installation will now begin. During the installation, the individual installers for each product will be invoked and appear as seen below:
  2. After all products have been installed, the installation summary will be displayed. Select Next to proceed.
  3. The installation is now complete. At this point, reboot your machine before using any newly installed software. This ensures the proper keys are written to the registry to allow the software to function correctly.
If you wish to install hardware drivers to allow you to program hardware within the LabVIEW development environment, proceed to the following section, Install Hardware Drivers. If you do not need to install hardware drivers, proceed to the Launch LabVIEW section.
After installing LabVIEW Student Edition and any modules or toolkits, it is now the correct time to install hardware drivers.
You can obtain the hardware drivers to use with LabVIEW in two ways: (1) from the Device Drivers DVD or (2) from individual installers. You can obtain the Device Driver DVD from your software administrator if you are on a campus that has an Academic Volume License (AVL), or you can download the individual driver that you need online (recommended).
Listed below are three of the most popular drivers:
  1. NI-DAQmx provides access to the large majority of NI multifunction data acquisition devices such as NI CompactDAQ, NI myDAQ, and the NI Educational Laboratory Virtual Instrumentation Suite (NI ELVIS).
  2. NI-ELVISmx  includes the NI-DAQmx driver and also provides a suite of software instruments to use with an NI ELVIS or NI myDAQ device.
  3. NI-RIO provides access to the NI CompactRIO and NI Single-Board RIO devices.
There are also many other drivers available to download, such as VISA, serial, and 488.2 (GPIB).
After you have downloaded or obtained the drivers that you wish to install, run the setup.exe file for each and proceed through the installation. After the successful installation of all drivers, restart your computer one final time.
Launch LabVIEW
After successfully restarting your computer, you are ready to launch LabVIEW. Navigate to Start»All Programs»National Instruments»LabVIEW <version>»LabVIEW <version> to open LabVIEW.
Next Steps
