I am trying to use my newly purchased SEA 9405 Module in my CompactRIO chassis, but I am seeing an error. I have tried on multiple systems and the error is consistent.
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at an unidentified location
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
