Single Column Listbox (Single-Selection)
- Create a reference to the Listbox Control, and place it on the block diagram.
	- Right-click on the Listbox Control, and selecting Create>>Reference.
- Move your cursor over to the block diagram to drop the reference.
- Create a property node to access the properties of the Listbox Control.
	- Right-click on the block diagram.
- Select Application Control>>Property Node.
- Connect the Listbox reference created in Step 1 to the "reference" input on the property node.
- Configure the property node to access the "ItemNames" and "Value" properties.
	- Click the bottom edge of the property node and drag down to expose a 2nd property item.
- Click on the top item labeled "Property" on the property node, and select "Item Names". (This should be in the bottom section of the list.)
- Click on the bottom item labeled "Property" on the property node, and select "Value". (This should be one section up from the bottom of the list.)
- Obtain the name of the selected item by indexing the "ItemNames" array with the value of the "Value" property.
	- Drop an "Index Array Function onto the block diagram. (Right-click on the block diagram>>Array>>Index Array)
- Connect "ItemNames" from the property node to the "Array" input of the "Index Array" function.
- Connect "Value" from the property node to the "Index" input of the "Index Array" function.
- Note that the "Index Array" function will return the name of the item currently selected in your Listbox as a string.
Please see the VI snippet, included in the "Results" section, for reference.
Single Column Listbox (Multi-Selection)
- Follow steps 1-3 from the "Single Column Listbox (Single-Selection)" section.
- Note that the "Value" property is an array of integers (rather than a single integer) for a single column Listbox with multiple selections enabled. This "Value" array will contain a single element for every item currently selected in the Listbox.
- Create a for loop to index the "Value" array.
	- To create a for loop, right-click on block diagram and select Structures>>For Loop.
- Wire both the "ItemNames" and "Value" arrays to the left side of the for loop.
- Disable indexing on for the tunnel connected to the "ItemNames" array.
	- To disable indexing, right-click on the tunnel, and select "Disable Indexing".
- Place an "Index Array" function inside the for loop to obtain the name(s) of the selected item(s) by indexing the "ItemNames" array with the value(s) from the "Value" array.
	- Drop an "Index Array Function into the for loop. (Right-click on the block diagram>>Array>>Index Array)
- Connect the "ItemNames" array to the "Array" input of the "Index Array" function.
- Connect "Value" element indexed by the for loop to the "Index" input of the "Index Array" function.
- Connect the "Element" output of the "Index Array" function to the right side of the for loop.
- Note that the output of the for loop will now be an array containing the name(s) of the selected item(s) from the Listbox.
