Can FlexLogger Split Log File for Different Channels During Runtime
Updated Aug 6, 2020
  • FlexLogger
I want to be able to log different data from different channels to seperate TDMS files. Is it possible to do this using FlexLogger?
It currently isn't possible to log to different log files through one project in FlexLogger.
It is possible to set up separate projects to log to different files, but it should be noted that you can't run multiple FlexLogger projects simultaneously.
