This error is being thrown by an invoke method within Excel Easy Text VI or Excel Merge Cells VI. The following fixes will prevent this error from being thrown.
- Change the Minimized enum constant connected to the Create Report.vi to Maximized, No change or Normal (One example can be seen in the snippet below.)
- Make sure you have the Microsoft Excel program fully opened before running your program.
Solution Snippet ("minimized" enum changed to "maximized")
If the above changes do not prevent this error from being thrown, check the following criteria:
- The error occurs after a specific length of execution time.
- You are using Microsoft Excel 2003 or earlier.
If your program meets these criteria, then this error is likely being thrown due to the pre-2007 Microsoft Excel spreadsheet size limit being reached.
