Your MP device IP setting: IP : 192.168.107.123 Mask: 255.255.255.0 Gateway: 192.168.1.1
Your PC IP setting: IP : 192.168.107.120 Mask: 255.255.255.0 Gateway: 192.168.1.1
Then directly connect the MP device and your PC through Ethernet cable, Open MPManager and you will see the corresponding MP device appearing in connection window.
A valid service agreement may be required, and support options vary by country.
