The header file is located in /usr/include as you can see in the picture below.
If you cannot see the header file in this location, please check if you have installed the NI Scope driver. You can check if you have installed the driver or not by calling yum list installed | grep ni-scope* . If the driver is installed correctly, you will see something like the picture below.
