If fault 12V output and LED off is the only problem, you can fix this by replacing a fuse of 12V output pin.
The front panel LEDs show the status of the +5 V and +12 V fuses.
You can either replace by your self or contact NI for a RMA request.
You can go to
here for applying the RMA request
