Is it possible to save as a previous version of VeriStand file?
Updated Jul 22, 2020
  • VeriStand
When I opened VeriStand file, a following error occurred. I think the file is created from a newer version of VeriStand.
Can I save this file as a previous version of VeriStand?
I remember that LabVIEW can save as a previous vi.
Following is the error massage.
"File Name" failed to load because it contains content that was saved in a newer version.
The document was last saved in VeriStand Version x.x.x.x Build x.x.x.x.
No, you can not save your VeriStand file as a previous version of VeriStand.
You can either install the same version of Veristand as the VeriStand version of the file or create a new file in the current version Veristand installed.
