Error -1074396077 With IMAQ Compute Average Image VI
Updated Jun 1, 2023
  • Vision Development Module
  • NI-IMAQ
When using the IMAQ Compute Average Image VI, I receive the error below:
Error -1074396077 occurred at IMAQ Compute Average Image
Possible reason(s):
Incompatible image type.
What can I do to fix this?
This error occurs when the Images and Image Dst inputs for the IMAQ Compute Average Image VI do not have the same type of image (8-bit, 16-bit, RGB, etc.). To fix the issue, make sure that both inputs use the same image type.
You can use the IMAQ Cast Image VI to convert the current image type to a specified image type.
The default image type for the IMAQ Create VI is 8-bit. You can specify a different image type by wiring a constant/control into the Image Type input node.
