LabVIEW Stops Responding After Placing NI DAQmx System Property Node in the VI
Updated Aug 13, 2020
  • LabVIEW 2019 SP1
  • NI-DAQmx 19.6
Using LabVIEW 2019 SP1 and NI DAQmx 19.6 driver:
  • If I place the DAQmx System Property Node in the block diagram of a blank VI and then I try to change the property, the menu doesn't appear and LabVIEW locks up.
  • If I just click the Run button after placing the DAQmx System Property Node LabVIEW also locks up.
This issue can be related to an incompatibility with the operative system or a corruption in the software. To solve this issue follow these steps:
