This message is a bug of NI License Manager (NILM), and does not impact software functionality. Dismiss the message and continue using the software.
- To avoid this message permanently, click on the dropdown and select Remind me when they expire or Do not remind me in the dialog box that pops up.
- You will need to complete this step for each piece of software (and its version) that is licensed through the disconnected license.
- The Remind me next time option is only available on newer versions of NILM, from 4.7 or higher.
If using NILM 4.7 or higher, you will see:
If using NILM 4.6 or lower, you will see:
