National Instruments does not actively maintain this document.
In the this first case, you can go to the Adaptec RAID Configuration Utility using the <Ctrl+A> option and go to the "Manage Arrays"menu to identify the failed disk. You can then either change the disk with a new one, or rebuild a new RAID0 Array with the 23 working disks.In the second case, please contact NI Support Team for RMA.
A valid service agreement may be required, and support options vary by country.
