Get the library reference through the
Library.Open invoke node. You can get a reference to each item through this library reference.
The important thing to do before changing properties is to check what type each item is. You can get the type of each item in the form of a string through the
LibraryitemTypeString property.
Finally, get a variable reference through the
VariableReference property. Now you can access the properties of each variable through this.
