Is It Needed to Install Python When I Deploy Labview Application Using Python Session?
Updated Jul 10, 2020
I developed a LabVIEW application using python session. When deploying it to a new PC, do I need to install python?
Yes, you need to install Python on the PC you want to deploy the application. Along with only being compatible with Python 2.7 and 3.6, the Open Python Node looks for the interpreter in the default installation directory of the system. If Python is not installed on the deployed PC, you will get the error about missing Python interpreter.
When you wish to automate Python installation for LabVIEW Applications, please refer to the related link below.
Support for Python sessions was added in LabVIEW 2018. If you do not have LabVIEW 2018, Perl and Python Scripts can be called from LabVIEW using the System Exec VI.
