在PXIe-4163 SMU上運行自檢時有過流保護錯誤
更新 Jun 15, 2023
產品資訊
硬件
  • PXI Source Measure Unit
  • PXIe-4163
軟體
驅動程式
  • NI-DCPower
問題敘述
嘗試通過NI MAX自檢我的PXIe-4163 SMU時,出現以下錯誤:
The self test failed.
The Overcurrent Protection (OCP) has been activated.  OCP is triggered when a fault condition occurs that would otherwise cause the device to sink or source current beyond its specifications for an excessive amount of time.  OCP might be triggered, for example, if a voltage greater than the operating range of the device is connected at the output, or if a voltage is foreced on the output that exceeds the Voltage Limit value when using the niDCPower Configure Output Function set to DC Current.
Channel Names: 17
Additional Error Info: Applicable Iso Captured: [103], Applicable Iso Sticky: [103], Applicable Niso Captured: [], Applicable Niso Sticky: [], Niso Captured First: 0, Errors Version: 1.3.3f1B111615
Error reported by instrument driver: -1074118582
當前沒有任何連接到SMU輸入。為什麼會看到此OCP錯誤?
解決方案
在自檢期間看到此錯誤表示該設備內部存在硬體問題。請聯繫NI技術支持以修理或更換該設備。
