The SystemLink Server can only work with previous versions of SystemLink Clients and cannot support any newer versions, whether they are major or minor updates of SystemLink.
Problems with connectivity between SystemLink Servers and updated SystemLink Clients can occur, even after a small version update, because of discrepancies in version compatibility. To resolve this issue, make sure your SystemLink Server is on the same version as your SystemLink Client, and then follow the instructions in the Installing and Configuring SystemLink Server and Clients section of the SystemLink Server user manual to set up the Server and its Client(s).
To assess the compatibility of software components within a SystemLink client environment, refer to the article SystemLink Client and External Dependencies Compatibility.
