This warning means that the number of channels that apply at
waveforms terminal of
SV Write to Buffer API is changed comparing to the default one. This warning occurs only at the first time when the number of input channels is changed. Since this is not the error, you could ignore this warning. You can use
Clear Errors.vi to erase the warning like below.
