When using non stream modes (queued or single point), frames I/O type are defined in the database. You can define the I/O Mode of frames as
CAN or
CAN FD when the I/O Mode of the cluster is
CAN FD.
When using stream mode in LabVIEW, you can specify the
I/O type of the frame in the
Data cluster of
XNET Write VI.
![](/servlet/rtaImage?eid=ka03q000000qycB&feoid=00N3q00000HUsuI&refid=0EM3q000001TCQP)
In LabWindows™/CVI, you can specify the
Type by assigning correct value to the 12th element of the array of bytes of the
Raw Frame Format that you use in
nxWriteFrame.
Note that you must use
CAN 2.0 Data (8) to transmit non-FD CAN frame in CAN FD I/O Mode. Non-ISO mode is not supported.
Please refer to attachment for modified shipping examples for LabVIEW and LabWindows™/CVI.
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at:
https://ni.com/samplecodelicense.
