Can I Simultaneously Output in Multiple Modes on A PXIe SMU?
Updated Aug 22, 2024
  • PXI Source Measure Unit
  • NI-DCPower
Can I have multiple outputs on my PXI Source Measurement Unit (SMU) running simultaneously in different modes? (i.e. Channel 0 running in Constant Voltage Mode and Channel 1 running in Constant Current Mode)
Yes, you can have multiple outputs on your SMU operating in different modes. Just make sure you are operating each channel within its defined specifications which you can search for here .
