Some of the test case are using the analog capture to detect the frame to decode. Depending on the device some answers could be difficult to detect as they are too close to our algorithm threshold. For those specific case we integer the manual mode where you can define cursor placement used for the answer decoding.
To activate this mode, follow the below steps:
1-Go on the Option tab
2-Then Test Case Option
3-Switch Manual Mode to Yes
4-Click on Save & Apply
Re-running the test case when you will encounter the same issue, a popup will appear with the analog trace.
- Please place the cursors around the missing answer
- Click on Ok.
The algorithm will analyse the trace.
