The Modifications in My Custom Step Type Are Not Loaded in TestStand
Updated Jun 25, 2020
  • TestStand
I use a custom step type in my sequence file but every time I modify the type definition (for example the default Post Actions), the new value is not loaded in my previous instances of the type.
Why is it not loaded?
Make sure that you didn't change the value of the Post Action in the instances. If the text is in bold, it means that you are not using the default value. So, if you change the default value of the custom step type definition, TestStand won't override your custom value.
