Using NI-DAQmx on CompactRIO to Program My C Series Module
Updated Jun 24, 2020
  • CompactRIO Controller
How can I verify if my C series module is compatible for programming with NI-DAQmx on CompactRIO ?
This document lists all the C Series modules with the compatibility information for CompactDAQ and CompactRIO.
If you see support in the document for your C series module under the Real-time programming mode of compactRIO, this would mean that you can use NI-DAQmx for programming the module.
Note that not all compactRIO models support NI-DAQmx programming. Refer to this KB article for further information.
