Resets to a default configuration all modifications previously made to menus, toolbars, and the docking state of panes. The Reset UI Configuration command loads the configuration you specify when you enable the Automatically Load Configuration at Startup setting on the UI Configuration tab of the Sequence Editor Options dialog box, otherwise, the Reset UI Configuration command loads the default Small Screen Example or Large Screen Example configuration depending on the screen resolution. TestStand considers a 1280 x 1024 minimum screen resolution as a large screen.
