Archived:Power Supply Requirements for HDD-8266
Updated Sep 8, 2020
National Instruments does not actively maintain this document.
  • HDD-8266
I have a HDD-8266 in an environment where I do not have access to regular 50 or 60Hz mains voltage. Can I use the instrument with a 400Hz supply?
Although not stated in the datasheet, the HDD-8266 only supports frequencies from 47Hz to 63Hz. Therefore it would be incompatible with a 400Hz supply.
