Can I Convert My NI LabVIEW FPGA VI Into VHDL Code?
Updated Sep 27, 2024
  • LabVIEW FPGA IP Export Utility
  • LabVIEW FPGA Module
I have written and tested my FPGA algorithm in LabVIEW using NI FPGA Module and NI FPGA Hardware. I want to deploy this algorithm on other Xilinx FPGAs. How can I convert my FPGA VI to VHDL code to integrate with Vivado Design Suite?
An FPGA VI can be exported as an encrypted netlist or plaintext VHDL code using the NI LabVIEW FPGA IP Export Utility.
This utility can be used to export your algorithm which can be integrated into your Vivado project and can be used on any Xilinx FPGA device of the same family. For example, an FPGA VI for sbRIO-9627 (uses Zynq-7020 SoC) can be exported into VHDL code and subsequently be integrated it into a Vivado Design Suite project for any Xilinx Zynq-7000 series SoC.
While most nodes available on the LabVIEW FPGA palette can be used as building blocks for the algorithm, the following nodes or features cannot be used:
  • Nodes that access external resources of FPGA chip:
    • I/O Nodes
    • DMA FIFO
    • Peer-to-Peer (P2P) FIFO
    • DRAM Memory
    • Interrupts
    • User-Defined Variables
  • User-defined component level IP (CLIP)
  • Local variables in the top-level FPGA VI. You can use local variables in non top-level VIs.
Refer to the attached getting started guide for more information about usage, capabilities and limitations of the LabVIEW FPGA IP Export Utility.
