You can not simulate a PXIe-5172 in NI MAX. However, you can simulate a PXIe-5172 in LabVIEW using the niScope Initialize With Options VI of the NI-SCOPE driver. This requires that you have the NI-SCOPE driver installed. In addition, you have to use correct model names 5172 (4CH - 325T), 5172 (8CH - 325T) and 5172 (8CH - 410T) for option string of niScope Initialize With Options function to simulate the corresponding PXIe devices.
The option strings are:
- Simulate = 1, DriverSetup = Model:5172 (4CH - 325T); BoardType:PXIe
- Simulate = 1, DriverSetup = Model:5172 (8CH - 325T); BoardType:PXIe
- Simulate = 1, DriverSetup = Model:5172 (8CH - 410T); BoardType:PXIe
