Python Has Failed To Initialize Using NI DIAdem
Updated Jan 27, 2025
  • DIAdem 2020
Programming Language
  • Python
I want to use Python with NI DIAdem 2020 via the Python installation directory provided in NI DIAdem 2020. When I try to run the script, I get the following errors:
DIAdem Evaluation Version
Initializing Python has failed
Error: Python is not initialized.
  1. Make sure the Python bitness matches the NI DIAdem bitness. NI DIAdem 2019 and above are available in 64-bit only.
  2. Use at least Python version 3.7.xxx. Kindly refer to the readme of the NI DIAdem version you are using to verify which Python version it supports.
  3. Make sure the Path in environment variable for Python is included.
  • If you want Python to work across multiple users, check that the Python directory is added to PATH in both User Variables and System Variables.
  • Manually add/copy the path if required.
  1. Ensure PYwin32 library has been installed on the Python version you are planning to use with NI DIAdem.
  2. Run NI DIAdem as Administrator.
  3. Add the directory location of the Python engine to DIAdem Settings:
    1. In NI DIAdem, navigate to Settings >> DIAdem Settings.
  1. Click on SCRIPT under the Panels section.
  2. Select Python as the Script language
  3. If installing different version of python, input the directory location pointing to the Python engine as the Python Installation Path. For example, the path to the standard python engine that ships with SystemLink would be: C:\Program Files\National Instruments\Shared\Skyline\Python\3.7\ *If you use the default Python version, leave the Python Installation path blank.
  1. Click OK.
  1. Restart NI DIAdem to have the Python configuration in NI DIAdem Setting take effect.
  2. NI DIAdem will now be able to run Python script without showing any error.
NI DIAdem 2020 does not support virtual Python environments. Only real Python engines install to dedicated directories registered with the OS.
