Wavelet Transform Using DIAdem
Updated Jul 10, 2020
  • DIAdem
I would like to perform Wavelet transform on my data using DIAdem. Is it possible?
No, it is not possible using DIAdem. The only workaround is to use WA Discrete Wavelet Transform VI in LabVIEW, then export the ready data to DIAdem to be visualized.
Be aware, that using VI mentioned above requires Advanced Signal Processing Toolkit.
