The reason this card is not listed is because Vision Acquisition Software focuses on protocol support, so, If you check on the readme and there is a point that mentions support for GigE cameras, then this driver supports the PCIe-8233. For accesing any readme file you can go to the
Vision Acquisition download page, select the
version you would like to consult, finally select
View Readme.
