RS Bistable : No Owning Project Error When Using RS Bistable Function Block
Updated Feb 9, 2021
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
When I put RS Bistable Function Block on the block diagram, my VI is broken. The error list says "RS Bistable : Created Without Owning Project". How can resolve this error ?
When you use RS Bistable or SR Bistable Function Block, your VI must be in LabVIEW Project Explorer. If the VI is in the LabVIEW Project Explorer, you will notice RS Bistable or SR Bistable item is added under your VI. In this case your VI does not have error related to this item.
If you add your VI which already has RS Bistable or SR Bistable Function Block in LabVIEW Project Explorer, you will still see this error.
You must put these Function blocks after you add your VI in LabVIEW Project Explorer.
