You can try uninstalling, reinstalling repair, and/or force reinstall. If that does not solve the issue, try the following:
1. Uninstall every version of LabWindows™/CVI™ on the computer.
2. Unregister the ActiveX control CW3DGraph by opening a command prompt and typing the following command:
regsvr32 /u “C:\Windows\SysWOW64\cw3dgrph.ocx"
3. Delete the file
cw3dgrph.ocx located in
C:\Windows\SysWOW64\4. Reinstall LabWindows™/CVI™ and check the control again.
If the behavior is still present, you'll have to reimagine the computer.
